offsetof macro in C
I just discovered this macro available in C: offsetof. Here is an simple example:
struct
  char a;
  int b;
  char c;
} example;
struct example s1;
unsigned int offset;
offset = (unsigned int)(&(((example *)(0))->b));
Thanks to offsetof (in the header stddef.h), the last line can be rewritten in:
offset = offsetof(example, b);
[via]
You may use these HTML tags and attributes:
<a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <s> <strike> <strong>
11 − 2 =
