Author Topic: [OpenGL Benchmark] Surface Deformer  (Read 94429 times)
« on: January 06, 2007, 12:09:07 PM »
Ceci est le topic pour tous les feedbacks, scores et toutes les autres choses relatifs au benchmark Surface Deformer.
This is the topic for all feedbacks, scores and other stuffs regarding the Surface Deformer benchmark.
DOWNLOAD: http://www.ozone3d.net/demos_projects/surface_deformer_benchmark.php
Overall Top-List
NVIDIA
ATI
01...... 17225 | fasterklander | 2900XT - GPU clock: 890MHz - MemClock:960MHz | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1813.html#msg1813
02...... 17200 | purecain | 2900XT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1636.html#msg1636 and http://www.xtremesystems.org/forums/showpost.php?p=2425631&postcount=26
03...... 17132 | electricl | 2900XT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1643.html#msg1643
04...... 16421 | mOOrk | 2900XT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1612.html#msg1612
05...... 15518 | vhco | 8800GTX SLI| XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1724.html#msg1724
06...... 15003 | electricl | 2900XT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1633.html#msg1633
07...... 14382 | fellix | 2900XT | Vista | http://www.ozone3d.net/smf/index.php/topic,203.msg1616.html#msg1616
08......  8385 | fellix | 2900XT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1255.html#msg1255
09......  7510 | gattonero | 8800GTX | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1396.html#msg1396
10......  7266 | desty | 8800GTX | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1204.html#msg1204
11......  7261 | JeGX | 8800GTX | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1203.html#msg1203
12......  7057 | SirLEO2000 | 8800GTX | Vista 32bits | http://www.ozone3d.net/smf/index.php/topic,203.msg1508.html#msg1508
13......  6137 | BrainDedd | 8800GTS | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1483.html#msg1483
14......  5981 | felynx | 8800GTS | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1559.html#msg1559
15......  2028 | fellix | X1900XT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1018.html#msg1018
16......  2024 | JeGX | X1950XTX | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg775.html#msg775
17......  1946 | Warkid1993 | X1900 | Vista | http://www.ozone3d.net/smf/index.php/topic,203.msg1731.html#msg1731
18......  1363 | Martin R | 8500GT | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1312.html#msg1312
19......  1069 | fellix | 6800GS | XP SP2 | http://www.ozone3d.net/smf/index.php/topic,203.msg1018.html#msg1018
« Last Edit: October 29, 2007, 10:21:13 AM by JeGX »
Re: [OpenGL Benchmark] Surface Deformer
« Reply #1 on: January 29, 2007, 04:25:56 PM »
GIGABYTE X1950XTX  - Catalyst 7.1:
fellix
« Reply #2 on: March 14, 2007, 10:09:31 PM »
  • Catalyst 7.2;
  • x1900XT 256MB @ 648/1692MHz;
Update with a 6800GS @ 500/1200MHz:
« Last Edit: March 16, 2007, 11:38:37 PM by fellix »
« Reply #3 on: March 15, 2007, 08:55:20 AM »
thanks for your contribution  ;)
desty
« Reply #4 on: May 21, 2007, 04:00:56 PM »
Avec une 8800gtx (Albatron) , aucune modifications, pilotes Version: 158.22
With Albatron 8800gtx , no modifs , Nvidia drivers version : 158.22
Les resultats sont impressionnants :
Impressive results:
« Reply #5 on: May 21, 2007, 04:51:40 PM »
Merci pour ta contrib!
yep voila le mien avec une 8800GTX / Forceware 160.02:
Le truc qui me pose problème est la trop grande différence entre ta machine et la mienne pour le meme type de carte
graphique. Le benchmark à l'air CPU-dependent ce qui n'est pas top (je ne pense pas que la version de driver explique
la différence). Je vais faire attention à ça pour le prochain benchmark qui est en cours de dev...
desty
« Reply #6 on: May 21, 2007, 05:09:01 PM »
Inutile de te donner cette peine , j'ai trouvé la source du probleme :
Apres avoir installé les memes drivers que toi j'obtient des resultats comparables :
Je voudrai bien me remettre a coder aussi , ce petit bench donne envi...
« Reply #7 on: May 21, 2007, 06:05:33 PM »
merci pour tes resultats! Donc mon bench n'est pas trop CPU-dependent ce qui me rassure.
Comme quoi le choix des drivers est important. Bon il faut dire que les 160.02 sont des drivers pour les quadro ce qui explique peut etre pourquoi il y a tant de diffèrence avec les 158.22.  Je vais en profiter pour poster mes scores avec le benchmark soft shadows.
baskapteijn
« Reply #8 on: May 24, 2007, 10:56:25 PM »
Hello people,
I was just surfing to find some cool aps that use gpu's as pseude general cpu, when i came across this gpu bencher. Here's my benchmark, performed on a XFX7950GT 570EXTREME
Thx a lot, bye! (ps i want folding @ home @ my card:(:(:( )
baskapteijn
« Reply #9 on: May 24, 2007, 10:59:13 PM »
Damn i cant add this on a reply , the picture. I dont want to go fucking around on servers to get it online so tell me , how do i add a picture that's not allready online to this forum, ?
« Reply #10 on: May 25, 2007, 07:25:51 AM »
Hey baskapteijn,  send me your picture ( jegx AT ozone3d. DOT net ) I'll put it online  ;)
baskapteijn
« Reply #11 on: May 25, 2007, 10:38:00 AM »
Hey there,
I've done my work, I own myself a webserver so that was no problem putting the picture over there. Here it goes!
Extra testing information:
XFX 7950GT 570 EXTREME http://www.xfxforce.com/web/product/listConfigurationDetails.jspa?series=GeForce%26trade%3B+7900&productConfigurationId=638442
Standard clock settings (570/1460 MHz)
« Last Edit: May 28, 2007, 11:11:54 AM by baskapteijn »
baskapteijn
« Reply #12 on: May 28, 2007, 11:11:15 AM »
Overclocked clock settings (610/1600 MHz)
E6600(2.4GHz) overclocked @ 3.2GHz
fellix
« Reply #13 on: June 19, 2007, 03:16:02 PM »
The mighty R600, no overclock:
« Reply #14 on: June 20, 2007, 08:59:19 AM »
Thanks fellix. It's the first time I see the 2900XT in action. Seems really poweful.
More than 1000 o3Marks better than NVIDIA's 8800 at vertex processing level. And what about Soft-Shadows benchmark
( http://www.ozone3d.net/smf/index.php/topic,158.0.html ) ?
