September 02, 2010, 07:51:51 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
News: Corsair AX1200 PSU And Two Highly Stressed GTX 480 in SLI (FurMark and EVGA OC Scanner)
   Home   Help Login Register
Pages: [1]
Author Topic: FurMark 1.4.0 is out!  (Read 24111 times)
WWW
« on: June 24, 2008, 12:58:19 PM »
FurMark is an OpenGL benchmark that stresses the GPU with fur rendering. FurMark requires an OpenGL 2.0 compliant graphics card with lot of GPU power!
FurMark's homepage and download: www.ozone3d.net/benchmarks/fur/
ChangeLog:
  • New: added full QXSGA mode: 2560x2048.
  • New: added an extreme burning mode for stability test. This mode available in command line: /xtreme_burning Launch FurMark-Xtreme-Burning.bat.
  • New: added command line parameters (see the start-Benchmark-Standard-Mode.bat file for parameters list). Now you can control FurMark's resolution, msaa level, CPU affinity, etc., using command line. This new feature has been added to allow FurMark to be used with OCCT (www.ocbase.com).
  • Change: time in score dialog box is now in milliseconds.
  • Change: improved driver detection.
Consigliere
« Reply #1 on: June 24, 2008, 04:27:33 PM »
Workaround for Vista issue:
right-click FurMark icon
select tabulator "compatibility"
tick the checkbox as seen in screenshot (whatever it's called in your language)
this disables "aero-glass" only for FurMark
Pages: [1]
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
