Author Topic: Demoniak3D Useful Links  (Read 21807 times)
« on: January 27, 2008, 01:55:37 PM »
Here is a compilation of useful links for creating realtime 3d scenes with Demoniak3D. Do not hesitate to post other links (free resources for instance). I will update this page on a regular basis.
General info and download
- Demoniak3D Download
- Demoniak3D ChangeLog
- Demoniak3D Homepage
- Demoniak3D BLOG
- Demoniak3D Online HELP and Reference Guide
GLSL Tutorials
- Fog with GLSL
- The Art of Texturing using the GLSL
- Vertex Displacement Mapping
- Normal-Map Compression
- Lighting in GLSL - Phong Model
- Image Filtering
- Ambient Occlusion Lighting
- Bump Mapping
- Introduction to GLSL
- GLSL @ Wikipedia
- Les bases du GLSL pour les Zéros
- Infos supplémentaires sur le GLSL pour les Zéros
LUA Tutorials
- LUA Tutorials Directory
- Introduction à la programmation LUA
- Demoniak3D LUA Host-API
- LUA Socket Lib et Coroutines
- LUA Coding
Demoniak3D Tutorials:
- Initiation @ media-pixel.net
- Presentation of Demoniak3D
Tips'n'Tricks:
- Problème de la jointure à la surface des meshes
- General Modelling Workflow
- LUA programming tips and tools
- Comments in LUA
- Ageia PhysX Drivers and Demoniak3D
- Multiples UV Maps
Exporter Plugins - 3D Studio MAX, Cinema4D
- Wak Exporter Plugin for 3DStudio MAX
- Wak Exporter @ Demoniak3D Blog
- Riptide OBJ Exporter Plugin for Cinema4D
Additional Tools
- DXT Viewer
- Camera Path Editor
- LynX 3D Viewer
- AOGen
Demos and code samples
- Demoniak3D DEMOS
- Demoniak3D Code Samples
Free 3D Models Resources
- www.turbosquid.com
- www.3dm3.com
- www.lynnart.net
- www.klicker.de
- www.3dvalley.com
- www.3d-resources.com
- www.3dtotal.com
Free Textures Resources
- Seamless Textures Pack
- www.2textured.com
- www.3dtotal.com
- Periodic Caustic Textures
Audio / Sound Resources:
- www.dogmazic.net
- www.jamendo.com
- musique-legale.info
- Free Sound samples at SoundSnap
- Bruitages
- www.pitjamajusto.com
« Last Edit: February 13, 2008, 08:18:07 AM by JeGX »
Dr. Goulu
    • Dr. Goulu
Re: Demoniak3D Useful Links
« Reply #1 on: January 28, 2008, 08:37:42 AM »
t'aurais pu mettre tout ça sur ton compte del.icio.us, et puis un link vers http://del.icio.us/darkshader ...
3Dmon
« Reply #2 on: January 29, 2008, 10:38:39 AM »
je prefère un accès direct au forum, c'est + rapide. que de passer par des séries de liens.
Will32
« Reply #3 on: February 28, 2008, 09:15:53 PM »
Hi, Iv downloaded the AOGen application, however when I try to run AOGen.exe the commnad promt flashes up for an instant and then closes. Am I doing something wrong or is it a bug in the program?
Thanks
SPRINGER
XNORMAL
« Reply #4 on: June 10, 2008, 12:20:54 PM »
est ce que quelqu'un a déj  testé le module Xnormal avec Demoniak ?
( baking ,AO, lowpoly, gloss map et plein d'autres choses)
ça a l'air d'une trousse   outils pas banale.
www.xnormal.net
« Reply #5 on: June 10, 2008, 01:07:19 PM »
Testé et approuvé!  :thumbup:
Comme  AOGen nouvelle génération tarde à sortir, j'ai utilisé CrazyBump pour mon orchidée en 3D.
Ca te permet de créer une map d'AO en un rien de temps (il me semble que les calculs se font sur GPU, donc c'est bien plus rapide que la plupart des solutions CPU) ; le résultat n'a pas toujours été parfait, mais avec quelques minutes de retouche ensuite j'ai obtenu l'effet voulu.
Pour les normal maps (avec gros et petit modele) ou le baking, je n'ai pas encore testé.
Depuis le passage au mode payant de crazybump, c'est probablement le seul logiciel gratuit aussi puissant.
« Reply #6 on: June 11, 2008, 10:41:05 AM »
oui vous faites bien d'utiliser xNormal, ce tool est cool. Quelqu'un a un screenshot à montrer d'une petite demo Demoniak qui exploite xNormal? Si le pont entre xNormal et Demoniak se fait bien, je vais mettre xNormal plus en avant.
« Reply #7 on: June 11, 2008, 12:27:26 PM »
Les screens de mon orchidée avec AO, puisque l'AO a été générée avec xNormal...
Par contre je n'utilise pas la map d'AO dans mon shader, en fait je l'ai mixée directement dans la texture.
