Author Topic: [OpenGL Benchmark] Fur Rendering - 1280x1024  (Read 114024 times)
vhco
Re: [OpenGL Benchmark] Fur Rendering - 1280x1024
« Reply #75 on: October 28, 2007, 08:56:33 PM »
Sorry vhco, I didn't see it  :oops:
Fixed. You have a SLI system I suppose ?
Yes, I do...
The new score is even better...
b/w I have a couple of new record scores for Soft Shadow and Surface Deformer as well which you have not updated since 09/30/2007.
« Reply #76 on: October 29, 2007, 10:29:27 AM »
Radeon 2400 pro is really ridiculous   :tropmdr:
Default clocks...
Gameslove
« Reply #77 on: November 29, 2007, 11:55:22 AM »
Fur Rendering Benchmark v1.1.0
Windows Vista 32 bit, Catalyst 7.11, no problems:
Windows Xp SP2 32 bit, Catalyst 7.11, light bug problem:
My sistem:
Intel Pentium 4 (640) 3200@3525Mhz/шина 800/2Mb cashe
Abit i945P (AL8-V)
1 Gb DDR2 533Mhz (A-DATA)(2 x 512Mb)
Palit ATI/AMD Radeon HD 2900 XT 512Mb GDDR3 512bit (CoreClock and MemClock default) No OC
« Last Edit: November 29, 2007, 12:03:38 PM by Gameslove »
Gameslove
« Reply #78 on: November 29, 2007, 12:00:26 PM »
My sistem:
Abit i945P (AL8-V)
« Last Edit: November 29, 2007, 12:03:04 PM by Gameslove »
wesley8
« Reply #79 on: November 30, 2007, 11:42:22 PM »
bug: I had 4GB DDR2 installed via windows server 2008, but fur rendering just shows 2GB.
My desktop:
Q6600 OC 3.6G(450*8)
4GB TEAM DDR2
ASUS 2900XT 512M
« Last Edit: November 30, 2007, 11:44:53 PM by wesley8 »
felynx
« Reply #80 on: December 02, 2007, 04:12:27 PM »
GeForce 8800 GTS OC 320Mo
P4 540 @3407mhz
« Reply #81 on: December 04, 2007, 12:26:45 PM »
Thanks Gameslove for pointing this bug out. I'm going to look at this asap.
« Reply #82 on: December 04, 2007, 12:34:02 PM »
Comparative table updated!
-blAck-
  • Guest
« Reply #83 on: December 05, 2007, 09:13:10 AM »
My result:
« Reply #84 on: December 05, 2007, 11:06:00 AM »
Thanx -blAck-, updated!
Gameslove
« Reply #85 on: December 05, 2007, 01:53:21 PM »
My sistem:
Abit i945P (AL8-V)
Palit ATI/AMD Radeon HD 2900 XT 512Mb GDDR3 512bit (810 Mhz CoreClock and 903 Mhz MemClock) OC
ness
« Reply #86 on: December 05, 2007, 07:18:17 PM »
Yes, I do...
Don't make me get another HD 3850 for crossfire and dethrone you.  I'll do it, I swear    :D  .  These new ATI budget cards are monsters for shaders and vertex performance -- running hand in hand with 8800GTS 320MB in games.   Simply  stunning for the price.  I'm about to upload some results here on my recently acquired HD3850, get ready to be surprised at the "mid-range" beast.
Sapphire Pure Crossfire Advantage • Athlon X2 3800+ @2750
Gigabyte 8800GT 256mb  • 2X512mb Kingmax DDR 500/ 2X256mb Samsung  • Ultra 500W x-connect  • 2X Hitachi 80GB Sata RAID0 • WD 250GB + Maxtor 120Gb • Soundblaster Audigy ES • Dual 120mm standard
ness
Ati Radeon HD 3850 running 750/2200 , Enjoy!
« Reply #87 on: December 05, 2007, 07:36:44 PM »
fellix
« Reply #88 on: December 14, 2007, 09:22:37 PM »
Zamoldac
« Reply #89 on: December 19, 2007, 02:33:23 AM »
hy there, i'm new here  :smile:... so i'l give it a go  [ Score: 3299 o3Marks ]  the card is a pro bios modded into XT basicly a Xt with 3 heat-pipes oc'd @ 859/1994
Vista x64 SP1 Rc1 ati cat. 7.11
« Last Edit: December 19, 2007, 08:59:37 PM by Zamoldac »
