Author Topic: [OpenGL Benchmark] Fur Rendering - 1280x1024  (Read 114023 times)
fellix
Re: [OpenGL Benchmark] Fur Rendering - 1280x1024
« Reply #30 on: August 28, 2007, 12:06:22 PM »
Looks like, the test is pixel shader heavy, most of the time. Just looking at the 7600 and 8600 results makes me think that.
Is a texture lookup is performed each pass, or only once?
KoDAk
« Reply #31 on: August 28, 2007, 04:44:36 PM »
Sorry
X550
« Reply #32 on: August 28, 2007, 06:04:22 PM »
thanks KoDAk  ;)
KoDAk
« Reply #33 on: August 29, 2007, 07:16:47 PM »
550\1400 MHz
KoDAk
« Reply #34 on: August 29, 2007, 07:20:24 PM »
550\1400Mhz
SirLEO2000
« Reply #35 on: August 29, 2007, 07:41:32 PM »
Is in this benchmark support for SLI? My friend can't start benchmark on 8800GTS SLI.
C2D E6600@3GHz, Asus P5N32-E, BFG GeForce 8800GTX Water Cooled, Kingston HyperX 2x1GB, Zalman Reserator 2, iiyama H481S-B6S, Logitech Laser Cordless Desktop LX-710, Logitech X-540, CoolerMaster Stacker 830+CM 850W.
Vista Ultimate BOX, Office Pro 2007 BOx
nenadus
« Reply #36 on: August 29, 2007, 10:03:08 PM »
Hi people,
Thank You for Your great software and comments.
I did few experiments with this benchmark on my machine and I got some strange results. You can find results attached. Just to mention, after I had started benchmark I minimized window and waited for it's termination. Have I told You I'm still beginner with OpenGL:)?
I'm wondering, why I got such results (big frame-rate). Whould I get approximate results in case benchmark rendered to texture and then painted rectangle with that texture (again minimized window)? Also, is there any computation on GPU while window is minimized (if we use window's framebuffer)?
Btw, second screenshot shows results when window is not minimized.
Regards,
Nenad.
« Last Edit: August 29, 2007, 10:11:30 PM by nenadus »
bleg
« Reply #37 on: August 30, 2007, 08:35:17 AM »
My X1900XT's in Crossfire under XP x64 :D
fellix
« Reply #38 on: August 30, 2007, 08:42:27 AM »
Update the drivers for your video card.
I've got some issues with an old Catalyst on a X1600, unable to render the fur effect, but able to finish the test.
« Reply #39 on: August 30, 2007, 11:13:48 AM »
yep the benchmark supports SLI. I don't know why but SLI is always a bit of a hassle to setup. So in my case, I did a fresh install:
1 - Uninstall forceware (from control panel)
2 - reboot
3 - run Guru3D Driver Sweeper to remove drivers waste. GDS is available here: http://downloads.guru3d.com/download.php?det=1672
4 - reboot
5 - install new forceware (162.50: http://www.ozone3d.net/smf/index.php/topic,743.0.html )
6 - reboot
7 - you're ok.
With these new and freshly installed drivers, I ran the benchmark with a 7600GS and with SLI disabled:
After that, I enabled the SLI:
and I ran again the bench:
Seems SLI is okay!
« Reply #40 on: August 30, 2007, 11:16:59 AM »
yes there is a little bug when you start the bench in windowed mode and you minimize it. But that's not the usual way to use the benchmak. Use the benchmark in fullscreen mode (default option).
So could you please run again the bench with all default settings ?
« Reply #41 on: August 30, 2007, 11:20:05 AM »
 Could you please run the bench with crossfire disabled to see the impact of Xfire ?
« Reply #42 on: August 30, 2007, 11:23:00 AM »
I've found this incredible score:  5133
The guy uses a BFG 8800 GTX in SLI mode!
LINK: http://www.overclock.net/software-news/231101-opengl-benchmark-ozone3d.html#post2663223
nenadus
« Reply #43 on: August 31, 2007, 01:38:21 AM »
Of course.
Nenad.
bleg
« Reply #44 on: August 31, 2007, 06:59:07 PM »
Single card performance:
