Author Topic: GPU Caps Viewer 1.2.0  (Read 5167 times)
« on: June 27, 2007, 08:17:02 PM »
The new release of GPU Caps Viewer is available. New web links and a functionality to test GLSL shaders have been added.
LINK: http://www.ozone3d.net/gpu_caps_viewer/
Thrust
Re: GPU Caps Viewer 1.2.0
« Reply #1 on: September 01, 2007, 05:56:02 AM »
My GPU Caps Viewer doesn't show me the GPU temps (the reason I installed it) for my 8800 GTX.  Am I doing something wrong??
Also the "3D View" causes 1 of my cores to run at almost 100% while this program is running.  Is that normal?
Win Vista 32-bit
eVGA 680i M/B
« Last Edit: September 01, 2007, 05:59:03 AM by Thrust »
« Reply #2 on: September 01, 2007, 09:47:41 AM »
Under Vista the GPU core temp is not displayed because of a bug in NVIDIA forceware driver. I signaled this bug to NVIDIA so wait and see.
3D View is a stress test so it runs the 3d scene as fast as it can so that's normal to see on of the core running almost at 100%.
