Author Topic: NVIDIA ForceWare Vista 158.24 WHQL @ Guru3D  (Read 1502 times)
« on: May 03, 2007, 08:25:11 AM »
The new version of the ForceWare driver for Windows Vista is available and is WHQL certified!.
Features:
* This driver fixes a problem when trying to enable NVIDIA SLI using the international versions of Windows Vista.
* Increased performance in 3D applications.
* PureVideo™ HD support.
* Add support for forcing Vertical Sync in DirectX applications.
* Updated NVIDIA Control Panel with improved user interface
* Numerous game and application compatibility fixes.
* This driver supports the following 3D features:
     o Single GPU support
         + DirectX 9 support for GeForce 6/7/8 series GPUs
         + DirectX 10 support for GeForce 8 series GPUs
         + OpenGL support for GeForce 6/7/8 series GPUs
     o NVIDIA SLI support
         + DirectX 9 support for 6/7/8 series GPUs
         + OpenGL support for 6/7/8 series GPUs
* DirectX 10 NVIDIA SLI support for GeForce 8 series GPUs will be available in a future driver
LINK 32-bits: http://downloads.guru3d.com/download.php?det=1629
LINK 64-bits: http://downloads.guru3d.com/download.php?det=1630
