Author Topic: Encapsulated 3D presentation  (Read 3337 times)
Lionmax
« on: April 07, 2014, 02:58:23 PM »
Hi
I’m interested to distribute 3D presentations to my clients using an encapsulated viewer files as follow
1.   the ability to develop the back end source scenes in 3D MAX,
2.   the viewer is able to display the Material developed in 3d max (option in LynX Light)
3.   the viewer is able to display the animations developed in 3d max
4.   the viewer has navigation buttons to enable the user to display next 3d scene when he finish from the current scene without loading 3ds files from the menu, in other words: next button will display the next 3d scene as if he displays power point slides
5.   the user can browse / rotate / zoom the objects in the scene (option is in LynX Light) using commands
is possible to get these options by any of your products or even customized code?
