Author Topic: GTX 260 Crashes at 2mins  (Read 1386 times)
Sublime
« on: September 30, 2010, 10:26:05 PM »
I ran the test four times over the last week. Each time I got the same result. It goes to 8000-9000 frames and around 86 degrees in roughly two minutes then my screen goes black (went red once and green once too) and I have to manual reboot.
Is this a overheating issue with my card or what? Not sure what these test results mean. I ran the test because I have recently had problems playing Starcraft 2. I can play maybe 5 mins before it will freeze.
I guess the ultimate question is, do I need a new card based on these results or is this a fixable problem?
This is my card, I have had it two years, with no problems and all the sudden it is acting weird.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127361
Thanks
Re: GTX 260 Crashes at 2mins
« Reply #1 on: October 01, 2010, 10:35:54 AM »
Certainly a problem with the VGA cooler. Maybe you could remove it, change the thermal paste and put it in place again...
Sandman192
« Reply #2 on: May 10, 2011, 05:25:18 PM »
It could be the power supply but you didn't say what wattage it is or what video card you have and if your using 2 or more in SLI mode.
