Author Topic: FluidMark will not finish?  (Read 2652 times)
Arctucas
« on: September 21, 2010, 01:04:11 AM »
Running 1.2.0, it gets to 99% and simply stops. ESC does nothing, ALT-TAB does nothing, I must CTRL-ALT-DEL and close the app (not responding) in Task Manager in Fullscreen, or close the program, which brings up the 'not responding' pop-up when in Windowed mode.
« Last Edit: September 21, 2010, 01:07:10 AM by Arctucas »
Re: FluidMark will not finish?
« Reply #1 on: September 21, 2010, 07:04:15 AM »
Do you have sth. like MSI Afterburner or EVGA Precision (i.e. RivaTuner statistics server) installed?
Then create an application profile with detection level=none
(Do the same for Tessmark!)
Arctucas
« Reply #2 on: September 21, 2010, 02:51:45 PM »
@Stefan,
Excellent, that seems to have done it.
Arctucas
« Reply #3 on: September 21, 2010, 03:13:11 PM »
Quick question: What is 'Co-op Mode' and how is it enabled?
« Reply #4 on: September 24, 2010, 09:39:38 AM »
Where do you see Co-op mode ?
I used this term in first alpha versions of FluidMark 1.2.x...
« Reply #5 on: September 24, 2010, 10:15:12 AM »
There is a line "Co-op mode enabled: NO" at benchmark submissions.
Arctucas
« Reply #6 on: September 26, 2010, 01:30:32 AM »
Anyway, I have another issue; when I try to submit a new result, I always get one that I did on Septmber 22.
Regardless of what settings I change, I cannot submit another benchmark.
« Reply #7 on: September 26, 2010, 07:52:53 PM »
Co-op mode is an old term for synchronous mode. Read this post for more information:
http://www.geeks3d.com/20100526/physx-fluidmark-how-to-get-you-multi-core-cpu-busy-at-100/
