Hyperion v1.0.4The 1.0.4 version fixes some little bugs and adds 3 new features:
1 - the inertia handling in camera movements. Inertia is enabled for each camera using the "inertia" attribut. You can change the damping factor with the "inertia_linear_damping" attribut.
2 - Now mesh cloning can be done in two manners: either each clone holds its own copy of vertices and faces or all clones share mesh data with the original mesh. It's obvious that in the second case, the creation of many instances will be faster but will forbid mesh data modification of a particular mesh.
3 - A "Recent Hypergraphs" menu is available and I have to say that's really handy! Th4nX to ougalougou! This menu is limited to the ten last opened hypergraphs.
