Author Topic: GLC_PLayer 2.1 is out. 3DXML and Collada 1.4 Support  (Read 4092 times)
laumaya
« on: September 22, 2009, 05:35:03 PM »
Hello every body,
GLC_Player 2.1 is released
List of the new fonctionnalities :
    * Add 3DXML V3 and V4 Ascii file format.
    * Add Collada V1.4 file format (Mesh, structure and materials properties).
    * Display axis to show view orientation.
    * Posibility to chose between "Track Ball" and "Turn Table" navigation mode.
    * Display the bounding box size in the view "Instance properties"
Links:
- GLC_Player
I think that GLC_Player is the first Open Source 3DXML viewer ;)
Laurent Ribon
Re: GLC_PLayer 2.1 is out. 3DXML and Collada 1.4 Support
« Reply #1 on: September 26, 2009, 05:41:28 AM »
For some reason the propeller looks odd on my rig: NVIDIA 8800GTX / Forceware 191.03
laumaya
« Reply #2 on: September 27, 2009, 10:13:52 PM »
Stefan,
There is a limitation when loading collada file with a texture containing Alpha Channel. GLC_Player doesn't detect the Alpha channel of the texture. Also, there is a work around. You can edit material properties in GLC_Player and store your modification in an Album like the album provide with GLC_Player.
Here's a screenshot of edition o the proppler's material :
And then change the Transparency (Alpha) value of the material.
