The problem is... if you set the time above the 60 second test you get higher scores.
A bug in the software?, it should be locked to 60 sec. only, then no one could place false scores.
I my self had no idea when adding more time while running the bench this is what would happen.
I did it as a test since I saw that most scores that are summited are unbelievable & in fact cheats as well...
That's If you want to call a flaw in the program a cheat that is. I think the whole page should be whipped,
fix it were the time is locked & start fresh with all new scores.
