Author Topic: SiSoftware Sandra 2009 SP3c available  (Read 1417 times)
« on: May 18, 2009, 04:49:53 PM »
SiSoftware Sandra (the System ANalyser, Diagnostic and Reporting Assistant) is an information & diagnostic utility. It should provide most of the information (including undocumented) you need to know about your hardware, software and other devices whether hardware or software.
Download from BMHQ.
Can s.o. double-check "GPGPU processing" (uses CUDA 2.2)? It crashes with my 8800GTX(G80). Old versions build around older CUDA versions ran fine :(
