Author Topic: NVIDIA GeForce 181.20 WHQL available  (Read 934 times)
« on: January 08, 2009, 05:20:59 PM »
    * Added support for GeForce GTX 295 and GeForce GTX 285
    * Enables NVIDIA SLI technology on SLI-certified Intel X58-based motherboards with all SLI-certified GPUs.
    * Enables NVIDIA SLI Multi-monitor support, giving you the ability to use two monitors with your GeForce graphics cards in SLI mode. Now you can easily switch between multi-monitor desktop mode and full screen 3D gaming mode. Learn more here.
    * Enables NVIDIA PhysX acceleration on a dedicated GeForce graphics card. Use one card for graphics and dedicate a different card for PhysX processing for game-changing physical effects. Learn more here. (Note: GPU PhysX is supported on all GeForce 8-series, 9-series and 200-series GPUs with a minimum of 256MB dedicated graphics memory. This driver package automatically installs PhysX System Software version 8.10.13).
    * Supports GeForce Plus Power Pack #2.
    * Added support for the new NVIDIA CUDA Video Encoder with H.264 optimization
ComputerBase claims to see less micro-stuttering.
Furmark, Fluidmark & GPUCapsViewer run fine.
Extensions down to 170, OpenGL3 is crippled.
Cryostasis is mashed as seen with Forceware 185.20
