MSI Kombustor 2.2.2
Our Softwares
GPU Tools - Benchmarking
my GTX260 maxcore reads 192
Topic: my GTX260 maxcore reads 192 (Read 3940 times)
peppy197
Associate
November 23, 2008, 02:50:12 PM »
My BFG GTX260 clearly labeled maxcore has 192 unified shader processors according to Caps Viewer 1.6.2
Should this not read 216 ?
Or have I been duped?
Allen
Consigliere
Re: my GTX260 maxcore reads 192
Reply #1 on:
November 23, 2008, 02:55:29 PM »
There are "old" GTX260 with 192 and new GTX260 with 216 shaders.
Double-check with
GPU-Z
Systeminfo:
CPU-Z
GPU-Z
GPUCapsViewer
peppy197
Associate
Reply #2 on:
November 23, 2008, 02:56:46 PM »
My videocard and the box it came in are also clearly labeled maxcore, meaning 216
But then again, maybe Caps Viewer is wrong
because it is reporting 4G physical ram for my installed 6G
Allen
peppy197
Associate
Reply #3 on:
November 23, 2008, 02:59:30 PM »
Yup
GPU-Z says 216
so its the Caps Viewer that is wrong then?
Allen
Consigliere
Reply #4 on:
November 23, 2008, 03:38:50 PM »
Well, i don't know how JegX counts the shaders, but you could submit a report from both GPU-Z and CapsViewer and provide the hyperlinks for comparison.
Do other 32-bit applications report physical RAM correctly, e.g.
PCWizard
CPU-Z
Last Edit: November 23, 2008, 03:52:53 PM by Stefan
Systeminfo:
CPU-Z
GPU-Z
GPUCapsViewer
Reply #5 on:
November 24, 2008, 10:18:43 AM »
Yes for GTX 260 MaxCore, shader processors count is wrong. Will fix this later.
Our Softwares
