Author Topic: GPU Caps Viewer database  (Read 7419 times)
digitdoubler
« on: October 30, 2008, 09:55:50 AM »
I feel almost embarassed to ask.... but could someone tell me how I search or view the GPU Caps data submissions on the ozone3d.net website? I can find a page with recent submisions but nowhere can I find the complete database. I'm sure it's staring me in the face...
Thanks!
Re: GPU Caps Viewer database
« Reply #1 on: November 24, 2008, 10:23:29 AM »
Currently only recent entries are displayed. I'll look at for a more complete database management later (no enough time now  :transpi: ).
HPew
« Reply #2 on: May 03, 2009, 07:49:21 PM »
You definitely need to leverage your database. Show the range of scores, averages for each card etc.
Chabi
« Reply #3 on: December 23, 2009, 07:36:47 PM »
Please updating the gpu database. My Radeon HD4830 card is 640 GPU cores, not 800
The lowest core/ram clock not problem, i using the 2D special profile.
« Reply #4 on: December 28, 2009, 06:08:42 PM »
GPU Caps Viewer 1.8.2 should fix the HD 4830 shader cores bug. Let me know.
Chabi
« Reply #5 on: January 29, 2010, 09:07:54 PM »
I submitted this:
Submitted by Chabi @ January 29 2010, 8:37 pm
GPU Caps Viewer Signature: GPU_Caps_Viewer_1.8.2_Build_Dec 28 2009_at_14:14:39
ARB Texture Units: 8
Vertex Texture Units: 16
Pixel Texture Units: 16
Geometry Texture Units: 32
http://www.ozone3d.net/gpu/db/index.php?which=34e2d252f4afa4bb9fa6fcdb5da3704f
This is a bug ?
Geometry Shader Texture Units: 16
« Reply #6 on: January 30, 2010, 05:04:32 PM »
Yes it's a bug in OpenGL tab. Correct number is 32.
Will be fixed in next release.
Thanks  :thumbup:
Chabi
« Reply #7 on: April 22, 2010, 11:49:32 PM »
Please added the single precision computing power under GPU Computing.
This two database inducles single precision performance:
ATI series http://www.hardware-infos.com/grafikkarten_ati.php
NVIDIA series  http://www.hardware-infos.com/grafikkarten_nvidia.php
Mem type: unknown ?
4830 use only GDDR3
« Reply #8 on: April 23, 2010, 02:35:34 PM »
Currently Mem type is valid for NVIDIA board only.
This field will be grayed in a next version for non-NV boards.
