Author Topic: New at everything about this  (Read 3405 times)
kholvautosk
« on: October 10, 2008, 04:32:53 AM »
Hey, i am completely new at making or even using is entire program and any like it. Would some one please help me learn how to even start in the first place.
I do not understand how to even get anything started or anything at all...
Thanks for the help...
Re: New at everything about this
« Reply #1 on: October 10, 2008, 01:57:46 PM »
Hello,
I think the best way to start would be to take a look at the code samples :
http://www.ozone3d.net/repository_hyperion_cs.php
They will help to to get used to Demoniak one step at a time !  :thumbup:
bingo
« Reply #2 on: October 19, 2008, 12:43:14 PM »
Same here I am as ignorant as everything. Where should i go if if i'd like to pursue further learning in regards to this. You see the internet is unlimited with information but the thing is it has so many links, sites and stuffs. Any suggestions?
« Reply #3 on: October 19, 2008, 10:20:40 PM »
I really think that the best way to start is to use existing Demoniak3D code samples and demos ; this way you can try to tweak some parameters, add or remove things and so on, without knowing everything. For example, if you want to use smoke or add an ocean, you can start with a demo with those effects, to see how it works.
Actually this is how I did my "toon snow" demo available here : http://www.ozone3d.net/demos_projects/index.php )
If you have any doubt on how to tweak a parameter, just take a look at the reference guide ( http://www.ozone3d.net/demoniak3d/devguide-v1/index.php?lang=2 ), and especially the "xml node reference" part.
The next step will be to take a look at demos using LUA scripting and GLSL shaders, and try to understand how they work. Don't hesitate to ask if you're lost !  ;)
« Reply #4 on: October 20, 2008, 10:45:43 AM »
bingo is a spammer, forget what he said  :police:
