Author Topic: Trouble benchmarking my GPU  (Read 1936 times)
dbx
« on: July 17, 2008, 10:31:04 PM »
Hi
I have a relatively old PC and GPU but the benchmarks I get seem very low. This is the result I get from FurMark 1.4.0 with the GPU overclocked ...
I have the same problem with 3dMark06 where it doesn't seem to run properly and gives very low scores(around 400)
It benchmarks well for this card with ATI Tray Tools but I understand that these benchmarks are unreliable
Games run pretty well considering - I can play Crysis ok
Any ideas as to what may be wrong with the benchmarking? Or is this result right???
All advice much appreciated  :)
« Last Edit: July 17, 2008, 11:52:09 PM by dbx »
Re: Trouble benchmarking my GPU
« Reply #1 on: July 18, 2008, 07:55:24 AM »
I think your score is correct. Look at the scores list: http://www.ozone3d.net/smf/index.php/topic,784.msg1467.html#msg1467
and you will see other scores like your. Your graphics card is not a monster and FurMark is intended to test high end graphics cards.
