Author Topic: OpenGL demos taking advantage of Shader Model 4  (Read 2252 times)
« on: June 22, 2008, 06:19:51 AM »
Naixela released two demos "geometry shader painterly rendering" and "geometry shader tessellation" taking advantage of Shader Model 4 (inclusive source code).
Found another one:
Integrator's GPU Particle System Demo
afaik GL_EXT_gpu_shader4 and GL_EXT_geometry_shader4 are only for NVIDIA cards, however as opposed to DX10 apps you can run them in Windows XP  :)
« Last Edit: June 22, 2008, 09:59:31 AM by Stefan »
