Author Topic: Creating FX found in Trapcode Particular with Hyperion  (Read 2642 times)
visuality77
« on: May 08, 2006, 06:45:58 PM »
I really like whispy line FX Like found in trapecode particular. Its like the
hottest plugin on the market for motion graphic and FX. I was wonder is it possible to create FX like that in Hyperion?
visuality77
Scatch that...
« Reply #1 on: May 08, 2006, 09:56:13 PM »
I just went throught the hyperion demos witha fine tooth comb
the is on a whole other level I suppose I would have to write
my own solution in lua script?
Any suggestions where to start to create an effect simular to
particular particle system, Somehow its made of little sphere
(light I suppos with no real light vaules except opacity and
britghtnes) they are strung together and Blurred? in such a
way as to create whispy lines and the viewer camera can infact
rototate around them, the viewing distance to is such that the little
spherical volumes appear to be a single volume string taperd
a both ends.
Can Lua script do this?
« Reply #2 on: May 10, 2006, 08:05:12 PM »
I've found a page on Particular Trapecode: http://www.trapcode.com/products_particular.html
Did you see the effect on this page? Or could you point me to a link that shows the effect?
